Message |
In 4th and 5th gears only, at 3000RPM for both gears, when I step on the gas and the boost goes 1/2 way between 0 and +14 (about 7.5psi boost (max 15psi) on boost controller, the RPMs shoot up. Does not happen in 1, 2, or 3 gears. If it is the clutch, I have had a Centerforce from Stillen for about 20 years. Do you guys recommend replacing with South Bend, Z1, or something else? If South Bend or Z1, then which model? I still have stock turbos, but will probably upgrade later on. Thanks
AndrewL 95 TT Stage 5+ "KRO"
Click on KRO for the most recent dyno chart.
